mikecreed
Oct 19, 2019Aspirant
Problem after upgrading Firmware to V1.0.9.88_10.2.88
I am having problems with my R7000 Nighthawk since upgrading the firmware to V1.0.9.88_10.2.88. Daily the router just loses connectivity for both LAN and Wireless and I have to reboot it to resol...
- Oct 19, 2019
Thanks for advice.
I have just downgraded to .42 release and re-built router/network.
Let's see how I get on.Has anyone from Netgear Support responded on the problems regarding the newer versions and when a fix to all the issues will be available?
Oct 19, 2019Guru - Experienced User
If/when you revert, make sure to do it over a hardwired connect and to reset the router afterwards back to factory. I'd agree with microchip8 that the .42 is the version you want to be on. There's been many issues with the version after that.
