mikecreed
Oct 19, 2019Aspirant
Problem after upgrading Firmware to V1.0.9.88_10.2.88
I am having problems with my R7000 Nighthawk since upgrading the firmware to V1.0.9.88_10.2.88. Daily the router just loses connectivity for both LAN and Wireless and I have to reboot it to resol...
- Oct 19, 2019
Thanks for advice.
I have just downgraded to .42 release and re-built router/network.
Let's see how I get on.Has anyone from Netgear Support responded on the problems regarding the newer versions and when a fix to all the issues will be available?
mpgrimes
Oct 20, 2019Tutor
I would agree .42 is the best for sure, but a factory reset after .88 seems to make a huge difference. im not worried about the features since im only using it in AP mode
