VanHool's avatar
VanHool
Problem updating firmware on Nighthawk X4S AC2600 R7800
I'm using my Nighthawk X4S AC2600 R7800 router as a network extender so I have it connected to my main router via a Cat 6 cable plugged into one of the LAN ports.   The firmware is an old version b...
  • plemans's avatar
    Jan 24, 2020
    Yes, you can manually update it.
    First download the firmware from the support site and extract it.
    Then, select ADVANCED > Administration > Firmware Update
    there will be a browse option. browse to where you extracted the firmware and select the file. then upload it.
    don't interrupt it while it uploads.
    https://www.netgear.com/support/product/R7800.aspx
