VanHool
Jan 24, 2020Aspirant
Problem updating firmware on Nighthawk X4S AC2600 R7800
I'm using my Nighthawk X4S AC2600 R7800 router as a network extender so I have it connected to my main router via a Cat 6 cable plugged into one of the LAN ports. The firmware is an old version b...
- Jan 24, 2020
Yes, you can manually update it.
First download the firmware from the support site and extract it.
Then, select ADVANCED > Administration > Firmware Update
there will be a browse option. browse to where you extracted the firmware and select the file. then upload it.
don't interrupt it while it uploads.
Jan 24, 2020Guru - Experienced User
VanHool
Thanks for that — I’ll give it a go!
