n1mm
Sep 27, 2016Aspirant
Problem using HTTPS with ReadyShare
Setting up Readyshare to allow access to a thumb drive from the internet. Works fine, except that the connection is HTTP and not HTTPS. I could deal with no support for HTTPS, but there is no way to...
- Oct 28, 2016
I got this reply from level 3 (via level 2) support:
Engineers confirmed that this is a device limitation and there is no security issue even if you are getting this message.
Please see engineers comment:
"This is a known limitation of all our product, NETGEAR only put this self-signed certificate in FW but not public to root server. Browser will give a warning but user can access page continually without issue. "
"This will not impact security, this just a warning regarding the certification is not recognize but public."I will ask for the ability to use port 80 to avoid the error messages.
n1mm
Sep 30, 2016Aspirant
Unfortunately, that doc does not correspond to what I see for that page on my router. I am running V1.0.2.04. In that version, the link name for the internet http link starts with HTTPS, not HTTP. Further, the port is restricted to 443 or >= 1024. The doc is not useful for my problem.
I guess no one is running V1.0.2.04 and trying to use this.
JamesGL
Oct 04, 2016NETGEAR Employee Retired
Hi n1mm,
Can you post the screenshot of the ReadyShare page of your router.
JamesGL
Community Team
- n1mmOct 04, 2016Aspirant
See: https://n1mm.mynetgear.com/shares/USB_Storage/Readyshare.PNG
You will see the issue with HTTPS/HTTP when you access that ReadyShare drive.
Since the doc shows HTTP and the ReadyShare setup page shows HTTPS, it sounds like HTTPS support is a new feature that either isn't working properly or I have configured improperly.
- JamesGLOct 14, 2016NETGEAR Employee Retired
Hi n1mm,
Accessing the ReadyShare via internet now use the HTTPS connection for security.
JamesGL
Community Team
- n1mmOct 14, 2016Aspirant
Not for me it isn't. It sets up an HTTPS url on port 443, but when I try to connect, I get a warning from my browser that the page is not encrypted. See https://n1mm.mynetgear.com/shares
Your browser will complain about the HTTPS being unencrypted. If you ignore that warning, it will take you to the directory that contains a screen shot of my ReadyShare Advanced Settings page.
