Marcin_Rydza
Oct 06, 2021Aspirant
Problem with connecting 2 identical drives to the R9000.
Hello, I have a problem with the R9000 - Nighthawk X10 AD7200. I am trying to connect 2 identical drives (ST2000LM 015-2E8174) through 2 identical USB adapters (Vendor: usb 0x1e1d "Kanguru Solutions...
Oct 06, 2021Guru - Experienced User
It could be that they're requiring to much power when connected at the same time.
Are they powered usb devices? or unpowered?
- Marcin_RydzaOct 06, 2021Aspirant
Thanks for the answer.
Seagate ST2000LM015-2E8174 (2.5 inch) drives are connected via the Icy Box USB 3.0 - 2.5 "(IB-256WP). They are powered by USB, but both drives keep spinning and LEDs indicate normal operation on both drives all the time.Regards.
- plemansOct 06, 2021Guru - Experienced User
right but if they both work while plugged in seperate, it isn't a router issue. Its more than likely they require to much power to be powered over the usb bus for both devices.
- Marcin_RydzaOct 07, 2021Aspirant
Ok, I'll check this set up using a cable with separate power, but it'll take a few days.
Regards.
