Marcin_Rydza
Oct 06, 2021Aspirant
Problem with connecting 2 identical drives to the R9000.
Hello, I have a problem with the R9000 - Nighthawk X10 AD7200. I am trying to connect 2 identical drives (ST2000LM 015-2E8174) through 2 identical USB adapters (Vendor: usb 0x1e1d "Kanguru Solutions...
Marcin_Rydza
Thanks for the answer.
Seagate ST2000LM015-2E8174 (2.5 inch) drives are connected via the Icy Box USB 3.0 - 2.5 "(IB-256WP). They are powered by USB, but both drives keep spinning and LEDs indicate normal operation on both drives all the time.
Regards.
Oct 06, 2021Guru - Experienced User
right but if they both work while plugged in seperate, it isn't a router issue. Its more than likely they require to much power to be powered over the usb bus for both devices.
- Marcin_RydzaOct 07, 2021Aspirant
Ok, I'll check this set up using a cable with separate power, but it'll take a few days.
Regards.
- Marcin_RydzaOct 11, 2021Aspirant
Hello again.I tested such a set:
Disks: 2 x ST2000LM015
Enclosures: 2 x Icy Box USB 3.0 - 2.5" HDD/SSD (IB-256WP)
Power cables: 2 x Delock 83176
Power source: Hama 2x USB-A 4.8 A (173608)It still has the same effect. Only the same drive is visible under 2 locations (U: \, T: \).
Regards.
- FURRYe38Oct 11, 2021Guru - Experienced User
Would be curious to see if this happens on 3rd party FW, Voxels FW is set up for the R9000. Something you can try and see if same thing happens, if not you can revert back.
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-54hf.74434/
I checked it on FW: V1.0.4.54.2HF Router Firmware Version (Voxel).
No changes. Both drives (U: \, T: \) are assigned to one drive. A change to one of the drives in the list produces the same change to the other drive (in the list). In fact, only one disk is seen.
