Marcin_Rydza
Oct 06, 2021Aspirant
Problem with connecting 2 identical drives to the R9000.
Hello, I have a problem with the R9000 - Nighthawk X10 AD7200. I am trying to connect 2 identical drives (ST2000LM 015-2E8174) through 2 identical USB adapters (Vendor: usb 0x1e1d "Kanguru Solutions...
Oct 11, 2021Guru - Experienced User
Wondering if the router only supports 1 USB drive connected at a time...
- Marcin_RydzaOct 11, 2021Aspirant
The router can handle 2 disks at the same time. For example, when replacing one of the ST2000LM015 drives with a Verbatim flesh (pen), the problem no longer occurs.
- FURRYe38Oct 11, 2021Guru - Experienced User
Possible same model convention used between two same model drives is confusing to the FW.
Yes, it probably is.
Any change of disk format, files (dos, gpt, fat32, efat, vfat, ntfs, ext4) doesn't matter.Regards.
