Marcin_Rydza
Oct 06, 2021Aspirant
Problem with connecting 2 identical drives to the R9000.
Hello, I have a problem with the R9000 - Nighthawk X10 AD7200. I am trying to connect 2 identical drives (ST2000LM 015-2E8174) through 2 identical USB adapters (Vendor: usb 0x1e1d "Kanguru Solutions...
Marcin_Rydza
Oct 11, 2021Aspirant
The router can handle 2 disks at the same time. For example, when replacing one of the ST2000LM015 drives with a Verbatim flesh (pen), the problem no longer occurs.
Oct 11, 2021Guru - Experienced User
Possible same model convention used between two same model drives is confusing to the FW.
- Marcin_RydzaOct 11, 2021Aspirant
Yes, it probably is.
Any change of disk format, files (dos, gpt, fat32, efat, vfat, ntfs, ext4) doesn't matter.Regards.
- FURRYe38Oct 11, 2021Guru - Experienced User
Ya seems like if you have two same brand and model drives, seems confusing to the router.
I'd try different brand and model but same size and go from there.
- Marcin_RydzaOct 14, 2021Aspirant
It is very possible that different drives will work. It is also very possible that you need to use SATA-USB connectors from different companies. Unfortunately, this does not solve the core problem, which is the FW bug.
Regards.
