devildoggod
Mar 22, 2019Aspirant
Problem with LAN Setup, Address Reservation
Hello,
Nighthawk X10 R9000 - Router Firmware Version V1.0.4.28
The router is functioning perfectly: fyi...
However, I have three devices that I add to the LAN Setup, Address Reservation -->...
- Mar 22, 2019
Use this as a guide, modify accordingly.
LAN address of router: 192.168.1.1
DHCP Pool 192.168.1.100 ~ 192.168.1.200
Assign a static IP, subnet mask and gateway to the Dell's NIC which is above or below the DHCP pool range specified above.
or
Re-enable the Address Reservation. Assign an IP which is (again) above or below the DHCP pool you've specified to the Dell's NIC MAC address. Leave DHCP enabled on the NIC, disable / enable the interface. It will grab the IP you specified in the reservation.
If you use my suggestion(s), the IP will never change, no device will ever get the Dell's IP and your port forwarding will work without issue.
antinode
Apr 27, 2019Guru
> Address reservation on the R9000 flat does not work.
"flat" or lumpy, a useful problem report of this type would include
the version of the (apparently defective) firmware. (And, as always,
an actual version number would be more useful than anyone's opinion of
what's "latest" today.)
ACCRG
Apr 27, 2019Aspirant
Serial Number=5V118B5Xxxxxx
Firmware Version=1.0.4.28.
TA=100-22419-01R10
Netgear R9000-100NAS
ACCRG
