IrvSp's avatar
IrvSp
Master
Dec 31, 2017
Problem with NET VIEW, W10, R7000, most recent firmware (including V1.0.9.20)
I really don't know when it started? I could always see the Router in NEW VIEW or using my Windows Explorer replacement Explorer++? Now I can't always do that?   When I run NET VIEW this is the res...
  • IrvSp's avatar
    IrvSp
    Jan 18, 2018
    EruvWeather, TheEther, guys, this is driving me nuts...
    As it stands NOW my wife's PC continues to have NET VIEW work properly, and has since I did a clean install of her X64 W10 Pro Ver. 1709. On the other hand mine will only work IF I reboot the Router and her PC is not on. Once her's comes on, it no longer works, and will never work again until I reboot the router.
    I opened the POWERSHELL on both PC's and ran "get-smbserverconfiguration" and compared results.
    Interesting, on mine EnableSMB1Protocol is set to True, but on her's, it is set to False?
    Checking Features installed I have SMB1 Server checked where her's has Client checked?
    Odd, what do you have?
    I've set mine to Client now but need to re-boot. Will update when I come back on.
    EDIT:
    FIXED IT!!!!
    GET-SMBSERVERCONFIGURATION now matches her's and it WORKS as expected!!!
    C:\>net view
    Server Name            Remark
    \\IRV8700              Irv's 8700
    \\LARAINE-XPS8500      Laraine's XPS8500
    \\READYSHARE           readyshare
    The command completed successfully.
    I don't KNOW how my SMB1 features were set or when, or even why.
    Suspect at this point a change happened during one of MS's Updates?
    Searching the web I found this page, https://community.spiceworks.com/topic/1995592-disabling-smb1-stops-domain-authentication marked SOLVED.... in it:
    M Boyle May 17, 2017 at 10:37 AM
    Did you try just disabling smbv1 and not actually removing the windowsfeature?
    edit: by running this command in an elevated powershell prompt:
    Powershell
    Set-SmbServerConfiguration -EnableSMB1Protocol $false
    Wonder if I did that it would have fixed it as well?
    EruvWeathergive this a try... might just work!
