Did you try just disabling smbv1 and not actually removing the windowsfeature?
edit: by running this command in an elevated powershell prompt:
Set-SmbServerConfiguration -EnableSMB1Protocol $false
EruvWeather, TheEther, guys, this is driving me nuts...
As it stands NOW my wife's PC continues to have NET VIEW work properly, and has since I did a clean install of her X64 W10 Pro Ver. 1709. On the other hand mine will only work IF I reboot the Router and her PC is not on. Once her's comes on, it no longer works, and will never work again until I reboot the router.
I opened the POWERSHELL on both PC's and ran "get-smbserverconfiguration" and compared results.
Interesting, on mine EnableSMB1Protocol is set to True, but on her's, it is set to False?
Checking Features installed I have SMB1 Server checked where her's has Client checked?
Odd, what do you have?
I've set mine to Client now but need to re-boot. Will update when I come back on.
EDIT:
FIXED IT!!!!
GET-SMBSERVERCONFIGURATION now matches her's and it WORKS as expected!!!
C:\>net view
Server Name Remark
\\IRV8700 Irv's 8700
\\LARAINE-XPS8500 Laraine's XPS8500
\\READYSHARE readyshare
The command completed successfully.
I don't KNOW how my SMB1 features were set or when, or even why.
Suspect at this point a change happened during one of MS's Updates?
Searching the web I found this page, https://community.spiceworks.com/topic/1995592-disabling-smb1-stops-domain-authentication marked SOLVED.... in it:
M Boyle May 17, 2017 at 10:37 AM
Wonder if I did that it would have fixed it as well?
EruvWeathergive this a try... might just work!
Still looking at this, might be wasting my time however. There are somethings that just don't make sense? The NEW VIEW has an oddity.
I issue the command on MY PC (192.168.1.30, name IRV8700) and get this:
C:\>net view
System error 1231 has occurred.
The network location cannot be reached. For information about network troubleshooting, see Windows Help.
OK, I know 'readyshare' exists so I do this:
C:\>net view \\readyshare
System error 53 has occurred.
The network path was not found.
Odd? I use the router's IP Address:
C:\>net view \\192.168.1.1
Shared resources at \\192.168.1.1
readyshare
Share name Type Used as Comment
Movies Disk read:all-no password;write:all-no password
USB_Storage Disk read:admin;write:admin
Let me try readyshare again:
Shared resources at \\readyshare
readyshare
What, it worked? SOMETHING had to have updated the MB, no? Who's to blame here?
Shortlived expectation, NET VIEW still fails with 1231, so was the MB updated or not?
Windows Explorer and Explorer++ both will show everything (on both operating PC's that are on) BUT the readyshare? However one can specify it via \\readyshare or NET USE x: readyshare and use it as a drive letter? What code is run on those programs and commands that it can find it but NET VIEW can't? In this case I'd think it was NEW VIEW code that is the problem, but then again, it might be processing a list that the MB keeps, which should be on the Router, or sent to a PC by the router.
More info is that after a period of time the DLNA Server doesn't operate on the R7000 but the Samba server did? This again could be an R7000 problem or a network problem based on IP Address resolution, again, in Windows or the R7000.
Irv ... I feel your pain! There is something wonky going on with certain W10 systems. No question. The question is what. There are other people reporting similar problems, just not specific to or blamed on the R7000. As I've said, if I open Windows Explore, click on "readylink" shortcut I created in "quick access" (so I don't have the type the address each time) ... if I click right away, Windows throws an error that the address is not reachable. Wait 30 seconds. There it is. As long as explorer stays open, there it is. If I close explorer, and open again after a certain amount of time - then it is rinse and repeat.
EruvWeather, your reply made me search Google again with different variants of W10, 1709, Master Browser, Explorer, missing shares.
Much to my amazement I found these:
Indicates this IS broken in 1703.
https://www.tenforums.com/network-sharing/85283-1703-master-browser-smb-broke-again.html
Another interesting one and SYS mentions he has a NG Nighthawk! Also note he was using Workgroup, NOT Homegroup. I am NOT using Homegroup either? Also his 'fix' is to use a flashdrive in the USB port, would not a USB drive be just as good?
Promising but NET VIEW complains a SERVICE is not started on 1709, not our problem.
https://appuals.com/fix-cannot-access-network-shares-after-update-1709/
Interesting one in that it claims it isn't working at all in 1709 without making changes. However, 2 things are different for us, we do not get the error it shows, and it DOES work for some period of time.
Interesting, on 1703, but it says putting a USB the router, shutdown all PC, reboot the router and IT will be the Master Browser. If so, and the problem continued to 1709, then the problem could very well be within the firmware on the R7000.
However, NONE of the above are a 100% match. In that none mention it would work and then wouldn't, nor get the 1231 error.
EruvWeather, TheEther, OK, I was looking at my Event Log today.. found a lot of these:
Log Name: System
Source: BROWSER
Date: 1/8/2018 3:53:13 PM
Event ID: 8021
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: Irv8700
Description:
The browser service was unable to retrieve a list of servers from the browser master \\READYSHARE on the network \Device\NetBT_Tcpip_{2EDDE305-16D3-4D87-B966-F36037B37451}.
Browser master: \\READYSHARE
Network: \Device\NetBT_Tcpip_{2EDDE305-16D3-4D87-B966-F36037B37451}
This event may be caused by a temporary loss of network connectivity. If this message appears again, verify that the server is still connected to the network. The return code is in the Data text box.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="BROWSER" />
<EventID Qualifiers="32768">8021</EventID>
<Level>3</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-01-08T20:53:13.677274700Z" />
<EventRecordID>21945</EventRecordID>
<Channel>System</Channel>
<Computer>Irv8700</Computer>
<Security />
</System>
<EventData>
<Data>\\READYSHARE</Data>
<Data>\Device\NetBT_Tcpip_{2EDDE305-16D3-4D87-B966-F36037B37451}</Data>
<Binary>CF040000</Binary>
</EventData>
</Event>
This was happening as I was opening Explorer++. Guess we know who the Win10 PC thought was the MB. This is probably because the READYSHARE share isn't seen in Network.
IrvSp... I do not use Explorer++, but have not seen any issues in the Event Log such as you reported.
One thing I did notice yesterday ...
The other W10 computer that does not manifest this issue is connecting to the network on my 2.4GHz band, which has a slightly different SSID than the 5GHz band.
The Win10 system that is experience the issue is connected via Ethernet, but the Network name is reflecting the 5GHz band name. Whereas, my Win7 system reflects the name I assigned to it. This is probably a dead-end, but interesting none-the-less.
I may try to disconnect the Ethernet and connect via the 2.4GHz WiFi just to eliminate any chance of some voodoo here.
IrvSpI have read a pleathora of articles, these three were new to me, so thanks for sharing. All are tantalizing, and at least reassuring the we are not alone. One thing is certain, tracking down the exact cause on a given system is seemingly impossible. One thing I will check later today, is if SMBv1 is still active on my other Win10 system where the issue is not manifesting.
Perhaps the scheduled removal of SMB1 has not yet taken place on that system.
Even if so, I would be hesitant to re-enable due to security issues (the cure perhaps being worse than the disease).
Clearly, there is some combination of Windows networking updates, the router employed, specific network configuration, and specific system settings that are at play here. I am guessing the issue with the R7000 does have something to do with SMB1 being supported, but perhaps not later versions. Regardless, this is clearly a fairly widespread issue, and therefore, Microsoft may be the primary culprit.
Agree with you also --- since I already have a USB drive attached, that is likely not going to solve the issue. FWIW ... I shut down our entire network every Friday evening (for Shabbat). I literally power down the modem, the router, etc. So, when I start up the next evening, the order is boot modem, boot router, power up readyshare drive, connect devices to WiFi. The only two devices that would connect immediately upon reboot are my two Amazon Fire TV sticks, but they are certainly not being assigned MB duties! (Also, I confirmed that "Readyshare"/router is the MB). The issue persists from network restart to network restart.
Keep me posted if you learn anything more. I will do likewise!
EruvWeather, check your EVENT VIEWER, under Warnings, on the first PC powering up, it should try to become the Master Browser. It should be there under BROWSER in the WARNINGS. Error ID:8021.
My PC that is failing is hard wired, Win10 x64 Home 1709 version. The other PC is my wife's wireless Netgear AC1200 adapter on the 5Ghz SSID, W10 Pro x64 1709, but it rarely gets powered up before mine. Her PC gets the 1231 error as well. There was a period of time when it would work fine with NET VIEW and my PC didn't, however not both report the 1231 error.
However her Error is slightly different from mine in the Event Viewer:
The description for Event ID 8021 from source BROWSER cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\\IRV8700
\Device\NetBT_Tcpip_{92F8A34C-2411-41B2-932F-177BC1F3AA20}
Now this was on her PC, and points back to my PC IRV8700, which pointed back to READYSHARE...
I suspect that at one point her PC was the MB when everything was working fine. At some point in time, her PC was not the BACKUP MB and that is when it started to get the 1231 error? Right before the warning in her PC she got an 8032 Information entry (under the Windows Logs, System).
Googling any strings in either 8021 or 8032 really doesn't fine much, certainly not new, other than how to shutoff the PC from becoming the MB?
EruvWeather wrote:IrvSp... I do not use Explorer++, but have not seen any issues in the Event Log such as you reported.
Doesn't have to be Explorer++, Windows Explorer should do the same. What I was 'saying' was that was the time I opened Explorer++ and selected NETWORK, and that generated the error. Same should happen if you open Windows Explorer and select Network. That is when the request is made to read the data in the MB.
EruvWeather wrote:IrvSpI have read a pleathora of articles, these three were new to me, so thanks for sharing. All are tantalizing, and at least reassuring the we are not alone. One thing is certain, tracking down the exact cause on a given system is seemingly impossible. One thing I will check later today, is if SMBv1 is still active on my other Win10 system where the issue is not manifesting.
No, the SMB1 I think is a red herring here. First of all SOME SMB1 stuff is still enabled on W10. If you go to Control Panel, Programs and Features, and on the left select Turn Windows Features on or off, and scroll down to SMB 1.0/CIFS File Sharing Support, you'll see ONLY yhe SMB 1.0/CIFS Client is not installed. The other 2 parts are installed.
This would only effect SMB 1.0 network devices anyway I think?
IrvSp... I do not have the warning in the event log. I have checked :-)
EruvWeather wrote:I shut down our entire network every Friday evening (for Shabbat). I literally power down the modem, the router, etc. So, when I start up the next evening, the order is boot modem, boot router, power up readyshare drive, connect devices to WiFi. The only two devices that would connect immediately upon reboot are my two Amazon Fire TV sticks, but they are certainly not being assigned MB duties! (Also, I confirmed that "Readyshare"/router is the MB). The issue persists from network restart to network restart.
Are you saying after the reboot of all parts (in the correct order) that NET VIEW still gives the 1231 error? I found that rebooting the router alone 'repairs' everything and until that READYSHARE share drops off the network it works fine. You should see the same working.
IrvSpI agree that SMB1 is likely not the issue. However, on my system, none of the SMB1.0 components are checked as installed. It is completely removed at this time.
EruvWeather wrote:IrvSp... I do not have the warning in the event log. I have checked :-)
Have you opened Windows Explorer and selected Network to view contents of the network with NET VIEW failing with a 1231 error? If not, do that and then check the Event Viewer.
IrvSpYes ... I am saying after a complete network re-start, the issue remains ... regardless of what order I boot up various computers that connect to the network. I have tried booting the affected system first, last and everything in between!
EruvWeather wrote:IrvSpI agree that SMB1 is likely not the issue. However, on my system, none of the SMB1.0 components are checked as installed. It is completely removed at this time.
Hmm, wonder why 2 parts are on in mine? Hmm, checked wife's PC, her's are ALL off?
Shouldn't matter but I wonder why mine are on? Possibly some other s/w I'm running? We've got the same Internet Security Suite, Norton's, but at one point I did have McAfee? My PC is newer even, and we both came from W8.1? Her's is also a Dell and Dell says her PC isn't supported for W10 but it works fine?
I have, and do not have the same warning that you are getting ...
EruvWeather wrote:IrvSpYes ... I am saying after a complete network re-start, the issue remains ... regardless of what order I boot up various computers that connect to the network. I have tried booting the affected system first, last and everything in between!
This is strange... I haven't rebooted the router for awhile. Matter of fact, when I started to look at when I first got the error it was 1/2/18, none before that? I know around that time I was trying a bunch of different flashes from V1.0.9.6 up?
Actually from my 1/2/2018 log:
[Time synchronized with NTP server] Monday, Jan 01,2018 08:23:14 [DHCP IP: (192.168.1.2)] to MAC address 10:AE:60:57:25:06, Monday, Dec 18,2017 07:53:02 [Internet connected] IP address: 67.8.xx.xx, Monday, Dec 18,2017 07:53:02 [USB device attached] The USB storage device WD 10EADS External (USB_ROUTER) is attached to the router, Monday, Dec 18,2017 07:53:02 [Internet disconnected] Monday, Dec 18,2017 07:53:01 [DHCP IP: (192.168.1.30)] to MAC address F8:B1:56:DD:6A:5B, Monday, Dec 18,2017 07:53:01 [Initialized, firmware version: V1.0.9.20] Thursday, Jan 01,2015 00:00:08
Oddly enough, that Dec. 18, 2017 date is problem the build date of the flash. 192.168.1.30 is my PC that installed the flash. Not until the Time Sync happened was the time corrected. 192.168.1.2 was one of out iPads that auto-connected.
It seems since then I've been getting those error 8021 errors on every boot and trying to look at the network? Wife was getting the 8021 errirs much earlier than that? Possible on my PC the part of the error log was wiped out when I did the flash from my PC, but I doubt it?
IrvSpThis should prove very interesting: On my other Win10 system which is behaving as expected with regards to resolving the network: SMB1.0 is fully installed! It is Win10 x64 Pro 1709, full patched (including today's patches), and SMB 1.0 is checked, as are the thre sub-boxes!
So, I am debating whether to disable SMB 1.0 on that computer to see if the issue is replicated, or enable it on my mis-behaving system to see if the issue is rectified -- knowing it is a bit of a security risk. (On the misbehaving system, SMB 1.0 is completely disabled ... no check boxes checked.)
Not doing anything immediately - but this does point to SMB1.0 and the R7000 being co-culprits in this mess, and also is somewhat reassuring that Win10 is actually behaving "as designed" a/k/a it's a feature, not a bug ;-).
Will report back if I become brave enough to enable SMB 1.0 on the system in question.
EDIT: https://support.microsoft.com/en-us/help/4034314/smbv1-is-not-installed-windows-10-and-windows-server-version-1709 ... I am guessing on one system, SMB 1.0 somehow was not used for 15 days and it uninstalled itself?
IrvSp... and look at this thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SMBv1-disabled-Readyshare-unavailable/td-p/1318587
... so based on this (and without having tested/confirmed myself, yet), I think the issue is that the R7000 is not fully compatible with non-SMB 1.0 machines.
A few more clues:
This is going to likely come down to weighing the security risk over the aesthetics of the Network places Explorer. Really leaning toward this being a SMB 1.0 issue and the R7000.
NETGEAR ... if anyone is reading this, some official insight would be beneficial.
IrvSpread through the comments at https://blogs.technet.microsoft.com/filecab/2017/06/01/smb1-product-clearinghouse/ ...
Specifically:
Greg Zoll
Computer Browser is used for the Workgroups, because SMBv2 & 3 require that service to discover other shared or available devices on the Network. It has nothing to do about the Domain alone, since the Domain has to use SMB protocols.
A fix needs to be pushed when SMBv1 is removed through the next update cycle, that Computer Browser Service stays and is changed from Manual to Automatic. Also Windows needs to be able to figure out that when a SMB Share off of a Server or NAS is set as Master Browser, that Windows does not just give an error message. Windows needs to be able to find out that it is not the Master of the Workgroup or Domain and in Settings under Network.
Reply
NedPyle [MSFT]
When SMB1 is gone, there is nothing for Computer Browser to use as a transport – it relies on SMB1. The goal is not to make NetBIOS/bowser work if we care about security.
EruvWeather, OK, ABSOLUTELY confused...
I rebooted the ROUTER with both PC's on. NET VIEW RESULTS....
Wife's PC gets 1231 error...
My PC:
Microsoft Windows [Version 10.0.16299.192]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\ispal_000>net view
Server Name Remark
Before rebooting, error 1231...
Yes, my PC does have SMB1 Automatic Removal and Server, but NOT the Client running. Wife's PC has NONE running.
I'll buy the SMB 1.0 is needed, BUT I don't understand why is wasn't working until I rebooted the Router. Obviously somehow the router dropped communicating and exchanging the list of devices. I.E., a Netgear firmware bug. Matter of fact, if it needs SMB 1.0, that alone is a bug, no?
In the referenced link for MS some points are also interesting:
Windows 10 Home and Windows 10 Professional no longer contain the SMBv1 server by default after a clean installation.
Both our machines came from Win8.1
Windows 10 Home and Windows 10 Professional still contain the SMBv1 client by default after a clean installation. If the SMBv1 client is not used for 15 days in total (excluding the computer being turned off), it automatically uninstalls itself.
This probably explains why my PC doesn't have the Client, but I just PROVED the Client isn't needed to see the READYSHARE disk.
In-place upgrades and Insider flights of Windows 10 Home and Windows 10 Professional do not automatically remove SMB1 initially. If the SMBv1 client or server is not used for 15 days in total (excluding the time during which the computer is off), they each automatically uninstall themselves.
Covers our PC case, but since I still have the Server installed I must be using it, if true?
Because the Computer Browser service relies on SMBv1, the service is uninstalled if the SMBv1 client or server is uninstalled. This means that Explorer Network can no longer display Windows computers through the legacy NetBIOS datagram browsing method.
No, this is NOT TRUE!!! First of all my COMPUTER BROWSER SERVICE IS running. Secondly, SMB 1.0 is NOT in the Dependency list. SMB 2.0 is.
Futhermore under Explorer Network Browsing on the link:
However, if you still have to use the Explorer Network in home and small business workgroup environments to locate Windows-based computers, you can follow these steps on your Windows-based computers that no longer use SMBv1:
Both of those ARE running and set to AUTOMATIC??? No, I did not change them.
So I think there could be 2 or 3 problems here....
So I'm trying an EXPERIMENT. I have TURNED off the 2 existing SMB1 features. I need to reboot, and I'll check NET VIEW when I come back up. Will EDIT with the results...
EDIT:
Turned them off, rebooted, 1231 error... ugh... But it got worse. Turned the 2 back on, no reboot required, 1231 error... OK, rebooted PC, 1231 error... WHAT IS GOING ON? Verified BOTH features are on...
Going to REBOOT the router and look at these commands:
C:\>time
The current time is: 19:12:02.43
Enter the new time:
C:\>net view
C:\>;reboot router now
'reboot' is not recognized as an internal or external command,
operable program or batch file.
C:\>time
The current time is: 19:13:03.36
Enter the new time:
C:\>time
The current time is: 19:15:21.04
Enter the new time:
C:\>net view
Server Name Remark
C:\>time
The current time is: 19:15:45.55
Enter the new time:
C:\>net view
Server Name Remark
Time stamped between them. READYSHARE is back!!! Took some time to come up though!
Soooo.... I think this is where we stand...
EruvWeather, TheEther, what do you think about this?
Of course, this in NO WAY explains why my iPad couldn't reach the DLNA server unless the R7000 was rebooted. It was working for me since my last R7000 reboot even with NET VIEW failing... another possible R7000 problem.
EruvWeather wrote:Will report back if I become brave enough to enable SMB 1.0 on the system in question.
I did disable it on a 'working' PC after I rebooted the router. See my EDIT in the long post, but YES, SMB 1.0, at least 2 features (suspect only the Automatic Removal possibly to build a new device list as one comes up or goes away?).
Only the Client and Server function will uninstall it says. Not the Automatic Removal feature... and as I pointed out in my reply above, for something that was updated in Nov. 2017 I think there are errors in it, see the reply to other message.
EruvWeather wrote:IrvSp... and look at this thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SMBv1-disabled-Readyshare-unavailable/td-p/1318587
Agree and I think I proved that, however, I think this is a bug in the firmware that it is using it, either that or NG is not aware of this fact. If this is the desired function, that they need it and it must be available, then it SHOULD be in the README.
EruvWeather wrote:A few more clues:
Both links don't really apply.
First is about access from non-Windows machines to Windows machines mainly. The second is from May 2017, but my problem wasn't seen until probably mid-Dec. 2017?
Both are close though.
Yes, I did not notice any issues until about six weeks ago also ... but it does speak to the role that SMB 1.0 plays.
I did not enable SMB 1.0 on the affected system. But, I did just map the drive (\\readyshare\readyshare) to see what would happen. Through mapping, the drive is immediately available, regardless of the fact it does not show up in the "Network Places" section of Explorer. Another strong indcator that while annoying, this seems to be the intended behavior that MS wants -- that NAS drives be mapped, and not "discovered."
Will live with this for a bit, since I am wary of turning on SMB 1.0 given the known security issues. I will keep you posted!
