Did you try just disabling smbv1 and not actually removing the windowsfeature?
edit: by running this command in an elevated powershell prompt:
Set-SmbServerConfiguration -EnableSMB1Protocol $false
EruvWeather, TheEther, guys, this is driving me nuts...
As it stands NOW my wife's PC continues to have NET VIEW work properly, and has since I did a clean install of her X64 W10 Pro Ver. 1709. On the other hand mine will only work IF I reboot the Router and her PC is not on. Once her's comes on, it no longer works, and will never work again until I reboot the router.
I opened the POWERSHELL on both PC's and ran "get-smbserverconfiguration" and compared results.
Interesting, on mine EnableSMB1Protocol is set to True, but on her's, it is set to False?
Checking Features installed I have SMB1 Server checked where her's has Client checked?
Odd, what do you have?
I've set mine to Client now but need to re-boot. Will update when I come back on.
EDIT:
FIXED IT!!!!
GET-SMBSERVERCONFIGURATION now matches her's and it WORKS as expected!!!
C:\>net view
Server Name Remark
\\IRV8700 Irv's 8700
\\LARAINE-XPS8500 Laraine's XPS8500
\\READYSHARE readyshare
The command completed successfully.
I don't KNOW how my SMB1 features were set or when, or even why.
Suspect at this point a change happened during one of MS's Updates?
Searching the web I found this page, https://community.spiceworks.com/topic/1995592-disabling-smb1-stops-domain-authentication marked SOLVED.... in it:
M Boyle May 17, 2017 at 10:37 AM
Wonder if I did that it would have fixed it as well?
EruvWeathergive this a try... might just work!
EruvWeather, check your EVENT VIEWER, under Warnings, on the first PC powering up, it should try to become the Master Browser. It should be there under BROWSER in the WARNINGS. Error ID:8021.
My PC that is failing is hard wired, Win10 x64 Home 1709 version. The other PC is my wife's wireless Netgear AC1200 adapter on the 5Ghz SSID, W10 Pro x64 1709, but it rarely gets powered up before mine. Her PC gets the 1231 error as well. There was a period of time when it would work fine with NET VIEW and my PC didn't, however not both report the 1231 error.
However her Error is slightly different from mine in the Event Viewer:
The description for Event ID 8021 from source BROWSER cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\\IRV8700
\Device\NetBT_Tcpip_{92F8A34C-2411-41B2-932F-177BC1F3AA20}
Now this was on her PC, and points back to my PC IRV8700, which pointed back to READYSHARE...
I suspect that at one point her PC was the MB when everything was working fine. At some point in time, her PC was not the BACKUP MB and that is when it started to get the 1231 error? Right before the warning in her PC she got an 8032 Information entry (under the Windows Logs, System).
Googling any strings in either 8021 or 8032 really doesn't fine much, certainly not new, other than how to shutoff the PC from becoming the MB?
IrvSp... I do not have the warning in the event log. I have checked :-)
EruvWeather wrote:IrvSp... I do not have the warning in the event log. I have checked :-)
Have you opened Windows Explorer and selected Network to view contents of the network with NET VIEW failing with a 1231 error? If not, do that and then check the Event Viewer.
I have, and do not have the same warning that you are getting ...
