mikgal
Oct 19, 2021Aspirant
Problema 5
Salve ho da poco impostato la rete di casa a 5ghz e WN3000RPv3 non riesce a trovare la rete, mi potete aiutare x capire se supporta anche la 5ghz o solo 2 grazie
Oct 19, 2021Guru - Experienced User
In inglese per favore
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
- mikgalOct 19, 2021Aspirant
Hi I have recently set the home network to 5ghz and WN3000RPv3 cannot find the network, can you help me understand if it also supports 5ghz or only 2 Thank you- FURRYe38Oct 19, 2021Guru - Experienced User
That would be due to this particular model Extender does not support 5Ghz signals:
https://www.downloads.netgear.com/files/GDC/datasheet/en/WN3000RPv3.pdf
Its a 2.4Ghz only extender.- mikgalOct 19, 2021Aspirant
WHICH MODEL SUPPORTS 5GHZ
