mikgal
Oct 19, 2021Aspirant
Problema 5
Salve ho da poco impostato la rete di casa a 5ghz e WN3000RPv3 non riesce a trovare la rete, mi potete aiutare x capire se supporta anche la 5ghz o solo 2 grazie
mikgal
Hi I have recently set the home network to 5ghz and WN3000RPv3 cannot find the network, can you help me understand if it also supports 5ghz or only 2
Thank you
Oct 19, 2021Guru - Experienced User
That would be due to this particular model Extender does not support 5Ghz signals:
https://www.downloads.netgear.com/files/GDC/datasheet/en/WN3000RPv3.pdf
Its a 2.4Ghz only extender.
