milton_7's avatar
milton_7
Initiate
Jan 07, 2016
Problems after Firmware Version V1.0.6.28_1.1.83 Update
When I uodated to Firmware Version V1.0.6.28_1.1.83, I lost all my wireless connections... I was able to reconnect some of my devices to the 5Ghz channel but the 2.4 Ghz channel does not appear to be...
  • milton_7's avatar
    milton_7
    Jan 08, 2016
    That is exactly what I did and it fixed the problem (revert the firmware to the previous version and reset the router)... However, it has really been a pain getting some my devices to connect to my router... I have 2-wireless printers that for some unknown reason would not connect to the router... I had to totally remove both of them from my computer and reinstall the software to get them to reconnect... I thought firmware updates were suppose to improve your system, not totally make it crash...
