Reenio
Sep 16, 2015Aspirant
Problems after updating R8000 firmware
I have a pc which only connects to the 2Ghz band but since updating the firmware it has very poor signal & drops out constantly. Other devices are connecting ok? Any known issues or fixes?
- Sep 16, 2015
Hi Reenio,
Please perform a factory reset and power cycle on the router after a successful firmware update. I also suggest making sure that the driver for the adapter of the computer is up to date. You may also use the Wi-Fi Analytics feature of the NETGEAR Genie app if you have it installed or any similar program to check for interferences and select the best channel.
Dexter
Community Team
Reenio
Oct 07, 2015Aspirant
Hi Rajos, Are you getting an error message? Im not an expert but I would check to make sure you are getting Internet access through your wifi.
Factory reset instructions are here:
http://kb.netgear.com/app/answers/detail/a_id/25156/~/r8000-faqs
Might be worthwhile posting this as a new question, there may be people who have had similar problems & fixes.
Good luck
Reenio
Good luck
Reenio
