JerryPar
Dec 20, 2018Aspirant
problems after upgrading to V1.0.9.60_10.2.60
Ever since I updated to the latest firmware I have had to reboot the router daily after loosing wi-fi. How do I solve this?
JerryPar
- Dec 20, 2018
Go back to the .42 firmware release. .60 is troublesome for many.
IrvSp
Dec 20, 2018Master
JerryPar
Dec 21, 2018Aspirant
Thank you for your help. I did rollback to .42 so I will give this a try. I did have trouble with an earlier update, not as bad as this, but it was fixed with the update after that one. So I decided not to wait this time but will look for something later than .60 and go to it.
I thank the other repliers also, it helped not falling into the same traps.
JerryPar
