mrstausen
May 22, 2021Follower
Problems loggin into extender netword
I bought a Netgear Wifi Range Extender AC750, model EX3110. I have tried setting it up with WPS and everything went fine until I had to log in from my device. I used the same password as I always use...
May 22, 2021Guru - Experienced User
Factory reset the extender. Push and hold reset for 7-15 seconds while its powered on.
that should get you back to thd defaults so you can use the installation assistant
