Frudah
Jul 16, 2021Follower
Problems with data packet loss in league of legends
Hey! For a while now I have experienced problems while playing league of legends. The problems are that every now and then, when a lot is happening on the screen or its early in the game or just ...
Jul 16, 2021Guru - Experienced User
1. what modem/gateway do you have?
2. what firmware is on the r7000?
3. does the issue happen if you directly connect the pc/laptop/console to the modem and use it? easy way to determine if the router is causing the issue.
