Peter1995
Jan 31, 2021Aspirant
Problems with Netgear Nighthawk AC1900 WiFi adapter
Hi guys. I have some problems with my adapter recently. Somehow I lose internet connection while I still have WiFi signal. I have tried to find some fixes but none of them have helped really. I...
Jan 31, 2021Guru - Experienced User
try this fix
https://www.youtube.com/watch?v=UQ526KawKFQ
- Peter1995Jan 31, 2021Aspirant
Hi.
Thanks for the suggestion, it didnt work, when i lose connection i can see the little blue led on the side blinking and then im thrown out of games or i lose connection, any other ideas?
- plemansJan 31, 2021Guru - Experienced User
you can always try the standalone driver.
Uninstall the current driver and utility. then install just the stand alone driver.
you can also try different usb ports. Maybe the port isn't supplying enough voltage/amperage during heavy continuous use
you can also try opening a support case if you're within your warranty period. click on "mynetgear" at the top. register an account and the device. From there you can start a support case
- Peter1995Feb 01, 2021Aspirant
Where do I find the standalone driver?
