Peter1995
Jan 31, 2021Aspirant
Problems with Netgear Nighthawk AC1900 WiFi adapter
Hi guys. I have some problems with my adapter recently. Somehow I lose internet connection while I still have WiFi signal. I have tried to find some fixes but none of them have helped really. I...
Peter1995
Hi.
Thanks for the suggestion, it didnt work, when i lose connection i can see the little blue led on the side blinking and then im thrown out of games or i lose connection, any other ideas?
Jan 31, 2021Guru - Experienced User
you can always try the standalone driver.
Uninstall the current driver and utility. then install just the stand alone driver.
you can also try different usb ports. Maybe the port isn't supplying enough voltage/amperage during heavy continuous use
you can also try opening a support case if you're within your warranty period. click on "mynetgear" at the top. register an account and the device. From there you can start a support case
- Peter1995Feb 01, 2021Aspirant
Where do I find the standalone driver?
- plemansFeb 01, 2021Guru - Experienced User
when you download the standard driver for it, it usually contains the driver/utilities and one called standalone.
Use that one. Just make sure you uninstall the prior driver/utility before installing the standalone
