srjohnson918
Feb 06, 2016Tutor
Problems with recent firmware update
Since updating three days ago, nothing can connect to this thing except through guest access. SSID, security, and passwords are all the same, but I am having to change everyones device to access thr...
- Feb 06, 2016
The latest R7000 firmware has been the talk of the forum for weeks.
Try a factory reset and reconfigure the settings by hand. Do not restore settings from a backup file. Turn off the new Arlo setting. If things don't recover, then downgrade the firmware. You can obtain firmware from downloadcenter.netgear.com.
srjohnson918
Feb 06, 2016Tutor
It has also blown up my home network. Other pcs are now off the homegroup, network printer (wired) works, but it can no longer find a pc, that used to be on the network, to scan a file into.
- TheEtherFeb 06, 2016Guru
