srjohnson918
Feb 06, 2016Tutor
Problems with recent firmware update
Since updating three days ago, nothing can connect to this thing except through guest access. SSID, security, and passwords are all the same, but I am having to change everyones device to access thr...
- Feb 06, 2016
The latest R7000 firmware has been the talk of the forum for weeks.
Try a factory reset and reconfigure the settings by hand. Do not restore settings from a backup file. Turn off the new Arlo setting. If things don't recover, then downgrade the firmware. You can obtain firmware from downloadcenter.netgear.com.
raven540
Feb 12, 2016Aspirant
I had the same problem used the same solution and everything is back as it should be. I could not agree more with the conclusion as to the lack of care exhibited in pushing out this firmware upgrade without proper testing or support after it clearly failed many people.
TheEther
Feb 12, 2016Guru
Netgear definitely should be held accountable for putting out bad firmware. But short of NASA-style development and testing (1 bug in 420,000 lines of code for the space shuttle vs hundreds to thousands of bugs in typical commercial code), people should understand that bad firmware gets out. It is exceedingly expensive to test code 100% (100% statement coverage does not equate to 100% path coverage).
What is more disappointing is that Netgear took so long to acknowledge that the firmware was bad and pull it. The engineers in the company should be empowered to pull releases. Many years ago in another company, I once put in a request to stop a big software release and ended up in the office of the VP of Engineering. I don't remember if it was my bug or someone else's, but it didn't matter. After I explained the severity of the issue, he gratefully thanked me. Hopefully the culture at Netgear isn't one where speaking up and/or taking action is frowned upon.
