Giovasnni
Aug 12, 2022Aspirant
Problems with router ac 1900 r7000
Hello, I hace a ac1900 nighthawk router and I'm experiencing some problems: The wifi network randomly disconnects from the internet (if I use a pc connected via cable while wifi is disconnected...
Giovasnni
Aug 13, 2022Aspirant
the firmware version is 1.0.11.136, the router is connected to a ZTE PON (I have a FTTH connection).
I do not have ipv6 enabled because I'm not using it.
The router was working fine until two months ago, after I got the first problems I upgraded the firmware, but the problems remain.
Now I'm using a different router and all the problems are gone, so I'm excluding problem related to the ZTE PON.
Giovanni
Aug 15, 2022Guru - Experienced User
Try enabling ipv6, If that doesn't help, you can always try downgrading the firmware a version or 2.
