wentigels
May 23, 2022Follower
Problems with router or internet?
I started having random connection problems. My internet has gone down maybe 4-5 times this week alone. This is very rare normally. I have Spectrum and have never had issues, mostly. I pay for 100m...
May 23, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. what current firmware are you on?
3. did you try checking firmware though the browser and not the app?
4. do all devices drop? Is it just wireless? Just wired? what actually happens? do they say, "connected, no internet". does the wifi stop broadcasting entirely? Details are key.
- wcalifasMay 24, 2022Prodigy
What I would do in your situation is research on these forums or other places on the net for "stable firmware" for R6700V3. I don't have that model so I can't help you out on the firmware. I would downgrade the firmware if there is something out there that someone says its stable. You can donwload firmware versions from the netgear.com website under the support section by writing your model number.
