Andrew97
Nov 17, 2020Aspirant
Problems with Security Key on R9000
Hello, I recently a used router and when setting it up through the Nighthawk app on my iPhone I am prompted to enter the Wi-Fi password for Netgear93. I have repeatedly tried to use the supplied passw...
- Nov 17, 2020
Maybe it was changed. Did you try factory resetting the router? Push and hold reset for 7-15 seconds while its powered on.
If that doens't work, you can cheat and just hardwire into the router via ethernet and set it up that way. That allows you to bypass needing the wifi password and you'll be able to change it during setup.
Nov 17, 2020Guru - Experienced User
Andrew97
I'll try reseting it later, but just in case that does not work, could you explain what you mean by "hardwire into the router?"
- plemansNov 17, 2020Guru - Experienced User
Using an ethernet connection from a laptop/desktop to the router.
The app based and wifi based methods are where we see the most issues with corrupt firmware
