DonPowell1959
Jul 23, 2021Follower
Product: R6900 Serial Number: 4E815A7AA2166 I need a power adapter
Product: R6900 Serial Number: 4E815A7AA2166 I need a power adapter Thank you, Don Powell
michaelkenward
Jul 24, 2021Guru - Experienced User
Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions to fit your router.
You can find them in all the usual places. Some will even list compatibility with different Netgear hardware.
schumaku
Look out for the ubiquitous Netgear PAV12V (12V 3.5A DC) power supply - it does drive many Netgear routers and APs. It's avaialble with different plugs and AC voltages, like PAV12V-100NAS for the 110..120V AC US and the like market.
Customer support can typically arrange replacement power supplies. Price would be higher than the eBay, Amazon, Newegg, even Walmart does have these available.
