theherm
May 07, 2017Aspirant
PS3 won't connect through WiFi
I've managed to connect my new R7000 once to my PS3 using WiFi. After that the PS3 won't connect to the router. Using a cable works fine, but I can't seem to be able to connect wireless. I've tried t...
- Jun 02, 2017
I've found the solution. I did put my ISP's modem/router in bridge mode, but appently Wifi was still on. Since I configured my Netgear router with the same SSID as the ISP's router, it probably was causing clashes or something. Anyway, after turing the Wifi signal off on the ISP's router, the PS3 is connecting flawlessly!
May 07, 2017Guru - Experienced User
If you tried the PS3 with out any security on the router, there maybe a problem with the PS3 or maybe not incompatible with newer generation wifi routers.
You can do this, install a wireless bridge with LAN ports in back. Routers or there are actual wireless bridge devices that you can use. Set up this wireless bridge with the PS3 LAN wire connected to the back of the wireless bridge. The bridge will connect to the NG router wirelessly.
Direct Wired LAN cable is best for game consoles however.
theherm wrote:I've managed to connect my new R7000 once to my PS3 using WiFi. After that the PS3 won't connect to the router. Using a cable works fine, but I can't seem to be able to connect wireless. I've tried turning WiFi security off, but it didn't work.
The R7000 is connect directly on the ISP's modem, which is switched to brigde mode.
- thehermJun 02, 2017Aspirant
- FURRYe38Jun 04, 2017Guru - Experienced User
Enjoy. :smileywink:
