theherm
May 07, 2017Aspirant
PS3 won't connect through WiFi
I've managed to connect my new R7000 once to my PS3 using WiFi. After that the PS3 won't connect to the router. Using a cable works fine, but I can't seem to be able to connect wireless. I've tried t...
- Jun 02, 2017
I've found the solution. I did put my ISP's modem/router in bridge mode, but appently Wifi was still on. Since I configured my Netgear router with the same SSID as the ISP's router, it probably was causing clashes or something. Anyway, after turing the Wifi signal off on the ISP's router, the PS3 is connecting flawlessly!
theherm
Jun 02, 2017Aspirant
Jun 04, 2017Guru - Experienced User
Enjoy. :smileywink:
