SSApple
Oct 19, 2020Tutor
PS4 Nat 3 R7960P AC3600 router
Model: R7960P — Nighthawk X6S AC3600 Tri-Band WiFi Router Firmware: V1.4.1.64_1.3.25 I have a problem switching my PS4 Nat type from 3 to 2. (I can't join VC on discord too, No Route error.) It ...
- Oct 20, 2020
Thank you so much. Your response helped me to look through everything again, and I found my issue.
I was only focusing on my netgear router control panel, but actually there was one more router control panel site(I don't know how to describe it, but basically I have two router login sites where I can configure the settings).
So, I reset both of them to the default settings...and it worked. I feel like dumbass spending two days trying to figure out, but now its all good.
Thanks.
Oct 20, 2020Guru - Experienced User
When you say you're switching back to AP mode, it makes me think you have another device before this router.
That'd cause a different nat type.
What modem/gateway do you have?
- SSAppleOct 20, 2020Tutor
Thanks.
