Baneling
Oct 16, 2023Aspirant
Public ip address on the R7200
Hi all, where in the R7200 does it report the public ip address?
Baneling
Oct 17, 2023Aspirant
Rogers helped me put it in bridge mode last time which was years ago. I dont know the password to get into the modem. The default doesnt work. I’ll have to contact them. Thanks
michaelkenward
Oct 18, 2023Guru - Experienced User
Sounds like a good move.
You said earlier, IP address is xxx.0.0.xxx.
If that is The ip address is 10.0.0.xxx, then that is a local IP address which is the sort of thing you see when a router sees another router in the setup process.
You started this conversation asking about the WAN IP address. Is that really what you want to achieve?
- BanelingOct 18, 2023AspirantUltimately what I want to achieve is my port forwarding working.
- michaelkenwardOct 18, 2023Guru - Experienced User
Baneling wrote:
Ultimately what I want to achieve is my port forwarding working.OK. You can't do that by putting the R7200 into AP mode.
- BanelingOct 18, 2023AspirantYou mean I can do that with the R7200 in AP mode?
Baneling wrote:
You mean I can do that with the R7200 in AP mode?No.
As I said "You can't do that by putting the R7200 into AP mode."
That is because in AP mode your router manages IP addresses and port forwarding.
- BanelingOct 18, 2023AspirantMy NG router is not in AP mode.
Baneling wrote:
My NG router is not in AP mode.I think we know that. Your problem is that your Ignite WiFi Gateway (gen 2) is probably also in router mode.
You need to sort that out before you try to use the R7200 to manage port forwarding.
That or work out how to tell your modem/router to handle the job in hand.
