jeepx19
Jun 10, 2021Tutor
Public IP assigned to Ethernet Ports
Hi Folks, An employee has an R7800 router which, when a device is plugged into the 4 ethernet ports on the router, it is assigned a public IP address. Joining to the WIfi Network on the device ge...
antinode
Jun 10, 2021Guru
> An employee has an R7800 router [...]
I've never touched one, so I know nothing, but...
History? New installation? Behavior change in a previously working
installation?
> [...] when a device is plugged into the 4 ethernet ports on the
> router, it is assigned a public IP address. [...]
Which sort of "a device"? Is it using DHCP? Is there a record of
which DHCP server granted that address? I wouldn't expect DHCP
(broadcast) requests to get through to the WAN/Internet interface on the
thing, if NAT is enabled. And I don't see a "NAT (Network Address
Translation) Enable/Disable" option in the R7800 User Manual (BASIC >
Internet).
What about two devices?
There are some other options which might bypass NAT, however:
ADVANCED > Advanced Setup > VLAN/Bridge Settings.
> This is a bit of a security issue [...]
More than "a bit", I'd say.
Knowing what I do, I'd start with a settings reset, and manual
(minimal) reconfiguration.
> [...] A firmware update is due. [...]
As always, an actual version number would be more useful than your
opinion of what's "due" today. But different firmware would be an
interesting second experiment.
