rwiggle
Nov 03, 2017Follower
QoS causes slow download speeds
I am having problems with download speeds when I turn on QoS. The speed drops from 65Mbps to 5mbps. I use Direct Tv Now in the house and when someone is using it then speeds drop on my main compute...
- Nov 03, 2017
You can download the older firmware from netgears support site and manual update the firmware not sure if the old qos will return then or not.
William10a
Nov 03, 2017Master
