duckware's avatar
duckware
Prodigy
Jan 21, 2018
QoS is gone -- no way to give cloud security cam highest upload priority
Upload QoS is gone, after being in Netgear routers for a VERY long time.  That feature has been removed.  Netgear support could care less.  Their response is 'so, that is just the way it now is'.   ...
  • JamesGL's avatar
    JamesGL
    Jan 22, 2018
    Hi duckware,
    If QoS is enabled, go to attached devices. Select on the device and select priority.
