justinrobert80
Oct 14, 2021Aspirant
QoS rules for a Nighthawk R7000P
I have searched and I find several places that walk thru the process but my web portal doesn't not give me the option to set up any rules. I do need to update my firmware which I will do asap. I am a...
justinrobert80
I don't have a problem with it not being fast enough. I am actually trying to single out one device and slow it's speed down. I have completed the firmware update however after doing some more reading on here it appears that Netgear has removed that as a feature from my model. Seems kind of a Hole thing to do but I guess it doesn't matter. I just won't be able to do it unless I purchase a different router that doesn't have that feature removed.
Oct 15, 2021Guru - Experienced User
The reason I asked about speeds is that qos isn't recommend if your speeds are greater than 250mbps.
- justinrobert80Oct 15, 2021Aspirant
Oh, sorry about that. I usually run about 100-110 Mbps.
- FURRYe38Oct 15, 2021Guru - Experienced User
Whats your uplink speeds?
