JohnnyWB
May 17, 2016Tutor
QOS Setup problelm
I have certainly has my share of problems with hi-tech gear with this thing being no different and this has caused me to once again look to this community for some answers. I am having an issue with...
- May 23, 2016
Hi JohnnyWB,
Try other web browser. If same with other browser, reset the router to factory default and manually reconfigure.
JohnnyWB
May 17, 2016Tutor
Yes, I am aware of it and do so but, it does not save them and I have to start all over each time.
VE6CGX
May 17, 2016Master
Did you try after logging in with ip address, 192.168.1.1?
- JohnnyWBMay 18, 2016Tutor
I will give that IP Address a try, later today, when I get off work. Thanks
That is not the correct IP Address and can't be located.
- VE6CGXMay 18, 2016Master
That is default address for Netgear router with user name/ppassword as admin/password. Are you running two routers?
Or have you changed the router address? If not, run command ipconfig /release, then ipconfig /renew, and ipconfig /all
after last command you'll see gateway address and ip address for the router, etc..
