JohnnyWB
May 17, 2016Tutor
QOS Setup problelm
I have certainly has my share of problems with hi-tech gear with this thing being no different and this has caused me to once again look to this community for some answers. I am having an issue with...
- May 24, 2016
Hi JohnnyWB,
Try other web browser. If same with other browser, reset the router to factory default and manually reconfigure.
VE6CGX
May 18, 2016Master
Did you try after logging in with ip address, 192.168.1.1?
JohnnyWB
May 18, 2016Tutor
I will give that IP Address a try, later today, when I get off work. Thanks
- JohnnyWBMay 18, 2016Tutor
That is not the correct IP Address and can't be located.
- VE6CGXMay 18, 2016Master
That is default address for Netgear router with user name/ppassword as admin/password. Are you running two routers?
Or have you changed the router address? If not, run command ipconfig /release, then ipconfig /renew, and ipconfig /all
after last command you'll see gateway address and ip address for the router, etc..
No, I am not running 2 wifi routers. I have the DSL Modem, that I have had for years and the Nighthawk wifi is all. I attempted to copy and paste or save and attach the whole thing but it will not allow me to. It shows the correct IP address but will not allow me to go there that way. I simply have to log in via "routerlogin.net"
