JohnnyWB
May 17, 2016Tutor
QOS Setup problelm
I have certainly has my share of problems with hi-tech gear with this thing being no different and this has caused me to once again look to this community for some answers. I am having an issue with...
- May 24, 2016
Hi JohnnyWB,
Try other web browser. If same with other browser, reset the router to factory default and manually reconfigure.
VE6CGX
May 18, 2016Master
That is default address for Netgear router with user name/ppassword as admin/password. Are you running two routers?
Or have you changed the router address? If not, run command ipconfig /release, then ipconfig /renew, and ipconfig /all
after last command you'll see gateway address and ip address for the router, etc..
JohnnyWB
May 18, 2016Tutor
No, I am not running 2 wifi routers. I have the DSL Modem, that I have had for years and the Nighthawk wifi is all. I attempted to copy and paste or save and attach the whole thing but it will not allow me to. It shows the correct IP address but will not allow me to go there that way. I simply have to log in via "routerlogin.net"
- VE6CGXMay 18, 2016Master
Did you enter the ip address in lieu of routerlogin.net?
- JohnnyWBMay 19, 2016Tutor
Yes and it will not allow me to access that page. I still have to go through "routerlogin.net" to gain access to this page so I can make adjustments. I am baffled by this, not sure what is going on.
- VE6CGXMay 19, 2016Master
If you are willing get rid of Genie(uninstall) reset the router and see. Insisting on using QoS, prepare to spend hours experimenting.
I had actually gotten rid of the Genie App but, re-installed it recently. Looks as though that may have been a mistake.
- JamesGLMay 24, 2016NETGEAR Employee Retired
Hi JohnnyWB,
1. What is the firmware version of the router?
2. What web browser did you use to configure the QoS System? Have you tried other web browser?
3. If the issue happens after you have updated the firmware, you may try to reset the router and manually reconfigure.
- JohnnyWBMay 24, 2016Tutor
The firmware version is V1.01.6 and I am using windows edge to access it, in windows 10 home
Hi JohnnyWB,
- VE6CGXMay 24, 2016Master
When you try other browsers, make sure you clear the browser cache first.
10-4, thanks all. I will try it.
