phaybein
Aug 30, 2015Follower
Qos Upstream and Downstream greyed out?
Hello,
I have the Nighthawk R7000 and I been trying to enable my Qos but it is greyed out and I can not select anything...any help would be great!
- Jun 21, 2017
Hi Norvell1984,
The router uses dynamic QoS.
https://kb.netgear.com/25613/How-do-I-enable-Dynamic-QoS-on-my-Nighthawk-router
VandenBerg
Jan 06, 2016Aspirant
I have the same issue with the R7000
1) setup as AP
2) firmware V1.0.6.28_1.1.83
3) Identical results with using Internet Explorer or Chrome
TheEther
Jan 06, 2016Guru
QoS is not available in AP mode. If you want QoS, then you should apply it at your primary router.
