phaybein
Aug 30, 2015Follower
Qos Upstream and Downstream greyed out?
Hello,
I have the Nighthawk R7000 and I been trying to enable my Qos but it is greyed out and I can not select anything...any help would be great!
- Jun 21, 2017
Hi Norvell1984,
The router uses dynamic QoS.
https://kb.netgear.com/25613/How-do-I-enable-Dynamic-QoS-on-my-Nighthawk-router
shahril8488
Mar 24, 2017Tutor
Hello TheEther,
Sorry for asking you the wrong question. My router is model r7800, in router mode. v1.0.2.28. I have tried to play with many configuration but still I could not get the downstream QoS tabbed appear.
I have selected Advanced->QoS Setup. There are only Quality of Service tabbed and WMM tabbed appeared.
Can you please advice me what to do? is the router broken?
Thank you in advance
TheEther
Mar 24, 2017Guru
I could be mistaken, but I believe the R7800 only supports Dynamic QoS. There should be a Enable Dyamic QoS check box. If you don't see it, can you try a different browser? Can you post a screenshot?
- Norvell1984Jun 16, 2017Aspirant
Is the r7000 suppose to have the QoS upstream and downstream options?
Mine does not... of course I am using firmware version 1.0.7.12_1.2.5
Will a frimware update make the option available or is ti not capable?
If not then does dynamic qos device priority options work the same way?- JamesGLJun 21, 2017NETGEAR Employee Retired
Hi Norvell1984,
- JamesGLJun 25, 2017NETGEAR Employee Retired
Hi Norvell1984,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
