phaybein
Aug 30, 2015Follower
Qos Upstream and Downstream greyed out?
Hello,
I have the Nighthawk R7000 and I been trying to enable my Qos but it is greyed out and I can not select anything...any help would be great!
- Jun 21, 2017
Hi Norvell1984,
The router uses dynamic QoS.
https://kb.netgear.com/25613/How-do-I-enable-Dynamic-QoS-on-my-Nighthawk-router
JamesGL
Aug 31, 2015NETGEAR Employee Retired
Hi phaybein,
Welcome to Community!
I would like to ask the following information so that I can best answer your inquir:
1. What is the firmware version of the router?
2. Is the R7000 set on an AP mode or regular router?
3. What web browser did you use to access the UI?
JamesGL
Community Team
- sc-rcSep 08, 2015Initiate
I am having the same problem. I have the latest firmware. I just updated it. I have the system set up as an AP
- VandenBergJan 06, 2016Aspirant
I have the same issue with the R7000
1) setup as AP
2) firmware V1.0.6.28_1.1.83
3) Identical results with using Internet Explorer or Chrome- TheEtherJan 06, 2016Guru
QoS is not available in AP mode. If you want QoS, then you should apply it at your primary router.
