papagiorgio200
Apr 23, 2020Follower
QUESTION About Lights: NETGEAR Nighthawk Cable Modem WiFi Router Combo (C7800)
 I need some direction to descriptors or what the lights mean in the lower left of the Nighthawk unit. I have three of the four lit. Two are white, one is orange. I will attach a link to my ONE-DRIVE ...
- Apr 23, 2020
the manual lists what these lights are.
https://www.netgear.com/support/product/C7800
I believe its your ethernet ports led's but couldn't see clearly from the video.
usually amber is 10/100mbps connection. White is gigabit.
Apr 23, 2020Guru - Experienced User
