Fxzith
Feb 16, 2024Aspirant
Question about the Netgear nighthawk ac2600
Hi, I have the nighthawk ac2600 R7450, my pc doesn’t have a built in motherboard so Can I use this router as a Wi-Fi extender? I have my pc in a different room so once I am done setting it up can I ta...
Feb 16, 2024Guru - Experienced User
AC2600 is a speed, not a model. What actual device do you have?
Some had extender mode but it was pretty rare. If its not listed in the manual, it doesn't have it.
You can always hardwire it in and use it in access point mode if its a router only device.
Doesn't look like it has a repeater/extender mode.
Again, you could hardwire it in and run it in access point mode.
If you didn't have ethernet, you could use a MoCa adapter or powerline.
another option if you don't mind possibly bricking the device is it looks like its capable of 3rd party firmware. It'd void your warranty and you'd need to use those forums for support but it'd get you some extra capabilities. maybe extender mode
