Donth's avatar
Donth
Questions about using network shares & security
I wanted to use my R7800 as a cheap backup solution until I can afford a dedicated NAS. I have a couple quick questions: Are port multipliers supported for raid 1? Have uPnP security bugs been pa...
  • Donth's avatar
    Donth
    Mar 04, 2018
    Thanks guys. After reviewing the other links it's apparent the routers Linux does not support standard port enumeration. If it doesn't work for usb it won't work for eSATA-hybrid which is a fancier USB port.
    In theory whenever you plug in a USB device there's a set enumeration of values that explain what the device is to the host. This is similar to how a Bluetooth device recognizes it's a speaker or a mic/headset/keyboard.
    This is why you don't need a custom driver Everytime you plug in a new usb keyboard or mouse or USB mem stick.
    Well there's a standard enumeration for storage devices and if they stayed current to the spec enumerating the port would have been supported.
    It's not a big deal. I'll just backup another way with redundant fallover until I can afford a real NAS with Plex support.
    I still think it's an awesome router. Way better than my linksys, even with the limitations.
