akhilsete
Jan 31, 2022Follower
Questions with Netgear Nighthawk travel router
Hi all, I hope this finds everyone safe and well. I purchased a Netgear Nighthawk M1 router, and couldn't be happier with it. This thing is incredible! I have four (hopefully quick and easy) que...
michaelkenward
Jan 31, 2022Guru - Experienced User
I have four (hopefully quick and easy) questions, that I was hoping I could get some feedback / answers to.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
