Kim09
Aug 23, 2021Follower
Réinitialiser switch GS116LP
J’ai un switch GS116LP mais impossible de retrouver son adresse ip. Je voudrais donc le réinitialiser afin de le re configurer mais il n’y a pas de bouton reset, comment puis je faire ?
1 Reply
Its an unmanaged switch. There's nothing to configure so there isn't a "ip address" to access it.
The only changes you can make to it are for the POE budget.
you can find details here:
