Catcharly
Jan 23, 2022Aspirant
Répéteur EX 6470 Débits internets
Bonjour, je viens d'acquérir le répéteur EX 6470, je l'ai configuré sans problème avec l'application Nighthawk, les diodes sont toutes au vert mais quand je fais un test de débit en wifi 2.4 sur ma t...
Catcharly
Good evening, thank you for the answer, if I understood correctly (I am French) if we are in an area too close to the network of the initial WIFI router, the repeater is useless?plemans
Jan 23, 2022Guru - Experienced User
Useless? No
But if you have a decent connection to the router at that point, its better to directly connect to it.
The Extender is going to add additional range or cover deadspots that can be created by materials in a home that block wifi
