Catcharly
Jan 23, 2022Aspirant
Répéteur EX 6470 Débits internets
Bonjour, je viens d'acquérir le répéteur EX 6470, je l'ai configuré sans problème avec l'application Nighthawk, les diodes sont toutes au vert mais quand je fais un test de débit en wifi 2.4 sur ma t...
Jan 23, 2022Guru - Experienced User
Its an expectation on how extenders work.
A single/dual band extender has to go router---->extender and then Extender---->device.
And it can't do both at once. So the speed gets but in half from what its receiving.
They work great at area's with dead spots but not so well on areas that still have coverage.
Catcharly
I understand but not very practical to use, maybe I need to move the repeater further away from the WIFI router? Thank you for your help.
