molson2
Sep 13, 2021Follower
R 8300 Firmware update
I tried many times to update firmware, it always failed. I need help. I have tried some fix’s on forum, to no avail
Sep 13, 2021Guru - Experienced User
How are you attempting the update?
what process are you using?
Where is it failing in the process?
Have you tried manually updating/
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
michaelkenward
Sep 14, 2021Guru - Experienced User
There was no answer the last time someone asked molson2 those questions:
Will not update. Never has updated. V1. 0 2.86_1.0... - NETGEAR Communities
Maybe they were, quite understandably, put off by the response they received there.
